Trying to come up with a fair price could use opinions
4 years 2 months ago #219548
by maxxadams1
Good morning all,
I have not been on the board in sometime. My original username is maxxadams. I could not login or reset my password so here I am, I could use some help. I am going to sell my D2 and I do not want to put a crazy price on it. Below is my basic write up. My initial thoughts and research thinks $5,000 USD is a fair price. Thoughts? If this is inappropriate to ask, I apologize.
Thank you for your time,
Michael
1949 Caterpillar D2 4U tractor/Dozer. 1 Family farmed owned from new Caterpillar. Recently reworked.
Main Engine: Rebuilt water pump, Head. New Pistons, rings, fuel injectors, coolant thermostat. All belts replaced.
Hydraulics: New seals, orings and filter for pump. New Glands and seals for the cylinders.
6480 hours on the tractor and ~10 hours on it after the rework.
A complete set of manuals, Parts, Owners, and shop manuals to maintain the tractor.
Almost Complete set of factory tools, still in wood crate from Caterpillar. Only 1 item missing the small oil can.
Precombustion chamber, injector tool set.
Alemite Chassis grease can with new hose.
Complete belly pan
Front belly hook
Electric start pony. New battery within the past year.
Belt drive
Front and rear PTO. Rear not mounted
Nose guard, not mounted
Light kit with 2 headlights
Complete record of correspondence on tractor purchased including original sales receipt and cashed check for purchase.
Straight blade, usable but needs some work to make perfect.
Thank you received: 191
4 years 2 months ago #219559
by D4Jim
Hey Michael, you can always come down in price a lot easier than you can go up!!
A key part of the condition of a Cat Tractor is the condition of the undercarriage. If the undercarriage is severely worn one can spend over the $5k just getting it replaced. I don't know if you can post pictures but they would be most helpful in determining the condition of the tracks ETC. One has to consider sprocket wear, rail condition and height and pin wear. Of course it depends on the buyer if they are only looking for something to run a few hours a year then the condition of the chassis is not that critical.
Good luck!!
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Thank you received: 9
4 years 2 months ago #219571
by ccjersey
I’m guessing there’s a dozer blade that goes with it since you rebuilt the cylinders....Which one? CAT or something else. Also which hydraulic system? Caterpillar made both #41 which were typically rear mounted and also #44 which were most often front mounted. I think both came in 1 or 2 spool versions so that’s important. How did the pto units work? You have the units but they’re not mounted?
X2 on the undercarriage affecting value. However with all the other things you have mentioned I think $5000 is a pretty fair price unless the tracks are falling off it. Rebuilding those engines isn’t getting any cheaper and may become nearly impossible with time.
4 years 2 months ago #219582
by drujinin
With all that is listed on a one Owner machine, 6000 plus hours on an Undercarriage is a lot.
But!
You need to take into account that a lot of those hours are probably "Ag" hours meaning that the Undercarriage still maybe in reasonable condition?
4 years 2 months ago #219618
by maxxadams1
Thank you all, this is perfect. I new you would get me thinking with Questions. This cat had 2 primary jobs on the farm, all AG. Pull a 2 bottom trip rope plow and run a belt driven corn blower. Most of the hours are as a power supply to a piece of equipment. The undercarriage is good, tracks not falling off or looking sad. The dozer blade is a Caterpillar 2S, and the Hydraulic unit is a type 44 mounted on the front. The Cat has not been a dozer long, maybe 12 years it was added to do small grading work or clean up potholes on our road, minor brush clearing. All told not even 100 hours with a blade on the tractor. So PTO is mounted on the front that runs the Cat Type 44 pump. The rear is mounted with a belt drive, I have a rear PTO as well and that is a separate unit from the belt drive. All turn well.. I also forgot to mention I made a new wire harness using Ancor Tinned marine wire with shrink fit tinned connections. This machine did not live outside but has had its own shed. Here some photo's of the undercarriage to see if this helps. I believe that answers all questions, and thank you for all the help.
Thank you received: 620
Thank you received: 34
4 years 2 months ago #219661
by Steve A
I think 5k is a reasonable price, You may get 6, its a nice machine with nice extras in books, paper work and tools.
