Working With Gaskets
Thank you received: 341
4 years 3 months ago #219430
by edb
from a photocopy of an older Service Magazine article on working with gaskets.
Thank you received: 183
4 years 3 months ago #219432
by d2gary
Thanks for this and perfect timing as I'm going to be reassembling my d2 shortly. Very interesting information
Thank you received: 153
4 years 3 months ago #219448
by rax200
Hi Eddy,
Thanks for the info as i am in the middle of putting my engine for 7U back together, and it is nice to know that i am doing the right thing by not using gasket goo, as i spent long time removing the old gaskets because some one used the goo.
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
4 years 3 months ago #219484
by edb
something to consider is that the info above is referring to gaskets that are still relatively new and so are still soft and pliable and not dried out and hard/in-compressible from sitting for 20 years in a hot store.
I can see that dried and likely hardened gaskets need to be re-hydrated with Diesel Fuel, oil, soluble oil mix, WD40 or such to get them pliable again before use so they can squash down and absorb any minor defects in the metal mating surfaces.
If the gaskets are hard they will not be compressible to do their job.
Any further comments or thoughts would be welcome.
Thank you received: 21
4 years 3 months ago #219502
by Misterskill
Interesting, I put a smear of loctite 5900 on almost all gaskets, except exhaust and petrol (gasoline). Diesel mechanics at work do it as well. Been alright so far.
4 years 3 months ago #219517
by Richard~J~W
My late Uncle used to say put water-pump grease on gaskets........didn't think to ask why and he's not here now.......can anyone put this little mystery to bed, please?
Thank you received: 9
4 years 2 months ago #219547
by ccjersey
Keep gasket from sticking and seal tiny pits in the flange surfaces?
Old Caterpillar mechanic I used to know always wiped a film of grease on gaskets before assembly. I’m sure it would make a difference on gaskets you might want to reuse like a pony motor base to clutch housing gasket.
Thank you received: 118
4 years 2 months ago #219613
by Ray54
Probably many better sealers but the old timers I was around used Gasgacinch brand. Go into any of the 3 or 4 independent parts houses in Paso Robles Ca,back in the day and ask for "Pretty Girl" and they would give you a can of Gasgacinch. You young ones may have to look up Gasgacinch and see the graphics on the can.
Today I still use Gasgacinch most of the time just because I always have. But if I think I might want to take it apart and reuse the gasket I put anti seize on one side. The same idea as the grease.
