D6 9u 42mt starter bendix/drive gear
4 years 3 months ago #219434
When you get all the right pieces together here's what you need to install. This is different from early instructions in that I've found the China unit castings are to thin to grind for wrench fit. By using a 5/8 x 1-3/4 NC button head cap screw with cut down 3/8 allen wrench no grinding is required. Put the cap screw in the Drive End Housing first then mount to the lever housing. Pictures attached.
4 years 2 months ago #219721
by docrw
Hello group,
This has probably been asked before but couldn't find it (easily). For people that have done all the current road work (as of 2020) what are the best parts and procedures for putting on an electric starter? My pony is working fine, but I want to keep it for cold weather starting and use electric for general use.
Could you guys help me with this?
I use this dozer so keeping it original is not important to me.
Thank you all in advance!
David
Washington state.
3 years 6 months ago #226751
by M00051
Finally proceeded to convert D6 to electric start and OMG it works awesome thanks to Old Magnet and others for all your expert advise. First time on new sight how can I apply pictures?
D4-7U
D6-9U
3 years 6 months ago #226772
by M00051
Attachment not found
I Would like to share my experience measuring, drilling the housing big 3 5/8 starter hole with latest measurements from Old Magnet 10.246 down from pony mount and 2.810 from engine mount surface , installing bare nose cone with long 5/8 bolt to fit 11 tooth drive gear to ring gear then drill and tap 5/8X11 starter mounting bolts, drill and add hole and tap the lever housing I had, assemble and install starter, fabricate battery box lower steel plate, fabricate intake mount, fill in hole where pony pulley was, add master switch and starter button, fabricate battery box, installed two 31 series batteries cabled parallel for monster 12V power, mounted original compression release to top of battery box AND STARTED!! None of this could be done without ACMOC! Vic
D4-7U
D6-9U
Thank you received: 409
3 years 6 months ago #226783
Hi Vic,
that's great news. Did it start easily and what was the ambient temperature? If it gets cold where you are, coolant heaters you can plug into an outlet are useful. By the way, for the missing pictures above, I wrote up a small guide in this thread (
www.acmoc.org/bb/discussion-d72/27700-test-neil-1#225950) about halfway down that describes the steps. The step to not miss is the one where you click the "Insert" button. The upload just puts the pictures on the server, but you also need to insert them into the actual thread. I think the reason the software is set up like that is so that you can use the same pictures in different threads.
3 years 6 months ago #226806
by M00051
D4-7U
D6-9U
3 years 6 months ago #226833
by M00051
Neil, Thanks for picture lesson now I need to figure out how to upload them like Old Magnet does where there smaller and you can click on them to make them bigger is doesn't take up so much space. Again there's no way I could have done any of this without ACMOC and Old Mqagnet's guidance. Thank You so much! Vic To answer your question when I finally got to start it was last fall the temperature was around 70F.
D4-7U
D6-9U
3 years 6 months ago #226837
What was the reasoning for going 12v? Surely it must get cold enough in Eastern Iowa to warrent 24v and glow plugs. Otherwise nice installation.
Time to create page: 0.211 seconds
