- Thank you received: 0
The SP suffix was used to designate machines that received optional INTERNAL components, not things like electrical system, direct electric start, hydraulic control etc.
Supposedly the D2 production was 100% for the US government and a set of non standard transmission gear ratios was installed in them all. The old joke was the gears were faster to outrun the bullets!
So, the total production during the war years have the SP designation. Incidentally there were no D2’s produced in 1943.
I have a 1944 5J
I have a 1944 5J
I have a 1944 5J
If you had one of the rare J series with factory direct start it most definitely would be a special parts situation.
In lieu of the standard hood you would have one with the opening for the battery.
In lieu of the standard dash with cutout for the pony you would have a flat dash with placement for the starter switch and other related equipment.
In lieu of the standard bell housing you have one machined for the electric starter, and yes this is a separate PN.
In lieu of the standard fuel tower assembly and intake manifold there was a separate assembly.
The list goes on here is a thread on the subject www.acmoc.org/bb/showthread.php?33437-D23J-direct-start
i would bet the sp is for the faster third/fourth gear installed in the transmission (i have heard of these called logging gear or roading gear also).... pull the top cover of the trans and count the teeth to verify.. it is shown in the parts book as an option. we have a 46 that has the faster gears in it.... interesting side note... at some point in its life -probably when fairly new- someone has welded the notch shut in the gear shift tower to prevent using 5th gear....the gears are all in there still...just can't use them.....fifth would beat the undercarriage apart quicker anyway.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
