#44 hydraulic control parts manual
Thank you received: 50
4 years 3 months ago #218966
by hfdzl
What is the form number for #44 hydraulic control that covers D2 tractor?
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
Thank you received: 104
4 years 3 months ago #218969
by Deebo
PM me your email and I’ll send you the pdf of the parts manual I’ve got. Also got the operating instructions if you need them.
Thank you received: 94
4 years 3 months ago #218974
by josh
There is more than one #44 parts catalog that covers the D2, form 31265 is specific to the D2, but was published in 1954 and will not cover all D2s, form #32888 published in late 1957 does a good job covering the #44 on the D2 and most other tractors at that time.
What is the serial # of the tractor and of the #44 unit and what is the application ? tool bar ? loader? etc.
Thank you received: 90
4 years 3 months ago #218984
by hfdzl
The tractor is a 1953 5U12016 4390 hrs. has 2A bulldozer blade and rear hyd hydraulic implement.
No tag on the #44, and no sign that it ever had a tag.
The one I want is 31265 but don't want to pay stupid money for it
4 years 3 months ago #218990
Are you looking in the right place for the s/n? Located on the back of the right rear lower side of the tank, barely visible on the tractor.
Better nail down the s/n if your going to need parts, they are not all the same.
Thank you received: 409
4 years 3 months ago #218992
I had to sand mine to find the serial # stamped into it. Located the two rivet holes, then sanded in between.
4 years 3 months ago #218995
by hfdzl
The 2 other 44 units i have, the tag is on the upper rear drivers side. This particular piece has no tag or any visible trace of a tag, rivets or stamping. I will take a chance on it being a 9W.
Thanks for all the interest.
4 years 3 months ago #219002
It will be there though Herb, just need to get the wire wheel on to find where it is. Mine is on the right / passenger side rear surface of the tank, can't remember top or bottom, but I swore it didn't have one either, until I went at it and found it. Is a 9W too, single spool. I'd love to have a twin spool for the 3J but I don't think the 44 mounts on a 3J. This was with the unit sitting on the bench in bright light too...
Time to create page: 0.182 seconds
