D5 (94J) Generator issues
4 years 3 months ago #218833
by kharville
Hi all. I have been trying to figure out why my batteries were not holding. Turns out that I get negative reading when I hit the glow plugs and nothing on the gauge when running. Hence, no charge. I pasted the wiring diagram I am using along with my regulator. Nothing is labeled and every wire is blue. Troubleshooting steps mention terminals Batt, A, F and G. I think I found Batt which has 24v present. The other 2 terminals on that side of the regulator along with the single wire on the other side test as dead short to ground. Is there a way to tell what is A and F on the generstor?
Thank you received: 409
4 years 3 months ago #218853
On my 5U, I had to carefully clean the regulator terminals and I found A, F, and something else stamped into the terminals. It was the same on the generator, so that might work for you. Wire brush and then a little sandpaper and then wipe with your finger to highlight any markings
Thank you received: 9
4 years 3 months ago #218854
by ccjersey
Bat is 1
Arm/GEN is 2
FLD is 3
Ground is 4-5 bypassing the rubber isolators
Have you polarized the generator?
Neil is right. If you remove the screws and clips holding the wires on, the terminals on the regulator are stamped. Never a bad idea to clean all connections.
4 years 3 months ago #218863
by kharville
Bat is 1
Arm/GEN is 2
FLD is 3
I plan on cleaning it up good. I assume to polarize I touch batt to arm briefly?
4 years 3 months ago #218915
by ccjersey
That’s the usual procedure for DELCO units.
4 years 3 months ago #218989
by kharville
I got it off and cleaned it. Terminals are indeed stamped. Under the cover looked perfect. What's the importance of the regulator being suspended by rubber? The little rubber bushings are gone. With a ground wire coming out the back is the little frayed ground wire needed also?
4 years 3 months ago #218997
by ccjersey
Yes ground wire is needed too.
The vibration is why the regulator is almost never mounted directly on the engine or generator itself. The regulators inside vibrate as part of their normal function, external vibration can’t help!
4 years 3 months ago #219143
by kharville
I got the regulator mounted again on the rubber isolation pads. Before I connected everything I wanted to check the Arm and Field wires from regulator to generator. I found all terminals had a short to ground. I then proceeded to the generator to find the ARM and FLD terminals grounded there also. Disconnecting the wires indicated no short to ground in the wires. In short I have the generator off now and it shows continuity across all 3 generator terminals. I guess I need to open it up as that doesn't sound right.
4 years 3 months ago #219144
by D6c76a
The simple solution would be to put a gm 1 wire alternator on her. What I did with d5 98j 525. Working like a champ.
Time to create page: 0.184 seconds
