Cat 60 (1926) information required.
Thank you received: 285
4 years 3 months ago #218670
by gauntjoh
A friend of mine who is a paid up (financial) member of the club is going to make a 1/5th scale model of a 1926 Caterpillar 60 tractor and would like the following information.
I'm really hoping that we will be able to help him.
He would like to know the pitch of the track chains and if possible the diameter of the sprockets and front idlers.
Does anyone know where he could obtain some drawings, especially of the 'back end' transmission case and final drives as he will need to make patterns and have castings made.
My friend does not use a computer and so I volunteered to help him as much as I can and will pass on to him any information gratefully received.
Many thanks in advance.
Best Regards John.
4 years 3 months ago #218716
by ianoz
Hi John , Perhaps you could find the person who made this amazing model to see if he would share his info .
4 years 3 months ago #218720
by gauntjoh
Hi Ian, that is a truly amazing model. The detail is incredible and it would be good to find out who made it, possibly Italian?
Thank you received: 34
Thank you received: 104
4 years 3 months ago #218762
by Deebo
WOW, that is amazing, thank you so much.
I'm going to have to persuade my friend to start using computers.
Seven years of work by the look of it! Incredible.
Thank you received: 15
4 years 3 months ago #218793
by D6 Pete
This cat 60 really is something to behold ,,, as I have a couple full size ,I know them well .. Its been up here to Queensland ,, where I live ,, This model in Canberra has got the track chain AND the pads right !! just wonderfull work .... Most or all models ive seen don't have the tracks just right .. ... Regards to ALL ....pete,.. I must add however,,i couldn't even build a model exhaust pipe for a cat60.!!!.
4 years 3 months ago #218794
by gauntjoh
Hi Pete,
Would you be able to help with the pitch of the track chains on the 60 and the diameter of the sprockets / idlers ?
Also, My friend would very much like to get in contact with the man from Canberra to compare notes so to speak.
From the blog, the tractor looks superb, I can only imagine what it must be like in the flesh !
Best Regards, John
Thank you received: 57
4 years 3 months ago #218795
by Wombat
Hi John,
Lindsay Drabasch built the SIXTY a number of years ago, I will call you and give you his phone number as he may not want it out here in the public domain.
The track pitch for a SIXTY is the same right through and including the D8 13A, I think the only change is in the actual rail height.
Regards, The Mad Mouth From The South
Thank you received: 77
4 years 3 months ago #218894
by Bruce P
Hi John. I measured my chain and it’s 16” center to center over three pins. The front idler is roughly 28 1/2”. The flange is 1” deep so where the tracks run is 26 1/2”. I measured the sprocket but I can’t remember the darned number. I’ll remeasure today.
Hope this helps
BP.
