Delco generator for 22/R2 Old Magnet
Thank you received: 50
4 years 3 months ago #218629
by hfdzl
Would anyone have the correct internal wiring for Delco single wire, 3rd brush generator 2B5602 ?
Have searched the internet, found several different connections, would like to be spot on and not fry the unit.
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
Thank you received: 341
4 years 3 months ago #218637
by edb
Hi,
sorry photo came out dark--scanner on the fritz--hope to sort it tomorrow--hope this helps as it is from my R4 SRB.
EDIT
As OM points out below, this diagram is for Am-Bosch ARKF Series Generators.
I will leave it here for others future Search Reference.
4 years 3 months ago #218656
by hfdzl
numbers are 939E 1341, 1858247
Thank you received: 44
4 years 3 months ago #218674
by GrantJ
Is a generator for an R2 the same as a 22? I dont have an R2 parts manual but I have been told that the R2 is almost the same as a D2, not a 22. The 22 takes a gear driven generator and a D2 takes a belt driven generator (at least the J series does. I dont know about the U series) Maybe I am missing something? Grant.
4 years 3 months ago #218676
by hfdzl
The 2F 22 and 5E R2 are the same. The 1J R2 is the same as D2.
Thank you received: 409
4 years 3 months ago #218677
Herb, is it a 1J R2? Reason I ask is my cousin's Twenty-Two is 1J3796W
4 years 3 months ago #218694
by hfdzl
The split may be different, that was just off the top of my head. Didn't open the book to look.
Early style 22 thru 1J5157
Thanks for keeping me straight!
Thank you received: 67
4 years 3 months ago #218760
by kittyman1
-is it a common fix, these old dozers that originally had generators, to update them with 12 Volt Delco's...? nobody here wants anything to do with a generator...unless it has to be 110% original etc..
-it's really common here with old tractors, on the Prairies...just fab the mounting, and very minimal wiring, simple, trouble-free solution...
Time to create page: 0.171 seconds
