D2 pony?
D2 pony?
4 years 3 months ago #218573
by Sf1066
Trying to get my new to me D2 pony running. It has no spark so I was checking the mag. Ended up pulling the mag. Found the drive gear with a tooth off. What’s the chance it was running like that? Could the broken tooth be somewhere it can’t hurt anything now? Seems like the cam gear is a little sloppy. The teeth on the cam gear show a little trauma but not bad. Guessing I will be pulling the motor off to have a look. What say you? If I’m pulling the pony is there some things I should be checking before it comes off? Thanks.
4 years 3 months ago #218593
by drujinin
That Mag MIGHT work once with the tooth missing but I would chance it!
Is this an early J style or later U style? Makes a slight difference in Pony removal.
Thank you received: 39
4 years 3 months ago #218598
by gemdozer
This magneto look like a WICO and with missing teeth on the gear you should check the flywell she must be shaking and by a bad front crankshaft bearing and check if the flywell is going up and dan and yes you better pulling the starting engine before more trouble.
Thank you received: 409
4 years 3 months ago #218599
You may be able to snag the broken-off tooth out of the gear chamber with a magnet, but if you can't, you'll need to pull the pinion assembly so you can fish it out. Don't be tempted to leave it in there
Thank you received: 341
4 years 3 months ago #218634
by edb
shaft breakage was an initial problem and when that was addressed then tooth breakage become the result with loose flywheel--as Hector said-- and/or excessively worn pony main bearings, also excessive crankshaft end float could be an influence as well.
4 years 3 months ago #218638
by Sf1066
Thanks guys. I suspect the flywheel is loose. It looks like the nut has been messed with. I have zero history on this unit and the former owner is deceased. So I guess I will pull it after planters stop around here. Looks like it’s going to take more than I hoped to get it to fire. Oh well.
D2 pony?
Time to create page: 0.141 seconds
