Thanks Old Magnet The soaking and a pry bar with a few tap of the hammer and the adjustment was a success. It moves freely now. should the clutch adjustment bolt be torqued and if so any idea of the pounds?
There is no recommended torque for the dry clutch....just the oil clutch.
Use your own judgment.....should be tight but not over done. They rarely get loose on their own.
