D2 3j donkey
D2 3j donkey
Thank you received: 10
4 years 4 months ago #217911
by caterpillarsam
Hi all
I’m after the part numbers for the two 20thou undersize crankshaft bearings in my D2 3j donkey engine.
Thanks in advance
D2 3J
WW2 Huber three wheel road roller (D3400 engine)
1937 Twenty Two
Cat SCOTE engine
Allen Oxford drawbar grader
1944 D7 4T1154
D8 8R
1956 David Brown 25C
1954 DW-15 scraper 45C653
Thank you received: 9
4 years 4 months ago #217917
by ccjersey
My parts book has
8b6 rear (Next to flywheel)
8b5 front
4 years 4 months ago #217918
by caterpillarsam
My parts book has
8b5 front
Yh I have that in my book as well, however it’s not a compatible part number that cat recognises if that makes sense, I need the updated part number
D2 3J
1937 Twenty Two
Cat SCOTE engine
1944 D7 4T1154
D8 8R
Thank you received: 409
4 years 4 months ago #217922
I have 3B7980 for flywheel bearing and 3B7979 for front of tractor bearing, and 2A3435 for the dowel (2 required). These numbers are for 3J1 through 3J4877. Then it changes to 8B6 which would be 8B0006 in Cat's system for the flywheel end and 8B0005 for the front of tractor. Dowel part # is unchanged
4 years 4 months ago #217986
by caterpillarsam
Thank you all, so handy you guys all helping me out
D2 3J
1937 Twenty Two
Cat SCOTE engine
1944 D7 4T1154
D8 8R
Thank you received: 48
4 years 4 months ago #218072
by mog5858
if you can't find them they are really quite simple to make with a lathe. as the are just 6060 AL. just add your oil clearance to whatever you got you crank ground too.
D2 3j donkey
Time to create page: 0.146 seconds
