- Thank you received: 1
Hi Flatop27,
welcome to the BB.
depending up your Serial Number your engine will need 22 Qts. of oil for S/No 8T1 to 8T16360 and 26 Qts. for S/No's 8T16361 and up.
If you filled to the dipstick High Level mark then you will be short of oil.
Also be aware that the Oil Clutch, which is part of the engine oil system, can hold an amount of the engine oil when cold hence the need for warm/hot oil checks as layed out in your grey Operation and Maintenance Instruction Book
If you happen to be not aware that Cat dipsticks are checked with the engine running at Low Idle and with Hot OIL (checked at end of each days running)--usual pre-start check can show the oil overfull by an average of around 1" overfull.
Always include your S/No when asking about your machine as Cat constantly does upgrades during production and so we can give you incorrect and possibly damaging incorrect data.
Hope this helps.
Thanks, sorry about that, the serial # is 8T 12795 SP. It has the dry clutch, but for sure needs to fill the oil cooler and filters. Think I will put it back together and fill it a little fuller. I didn't actually time how long I had it spinning, when I didn't see any pressure on the gauge, my heart kind of skipped a beat. It has always pegged the oil pressure needle pretty quickly when I would spin it before I left it set. Thanks for the response
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
