I wonder if I can repair this repair? (7U Pony block)
Thank you received: 42
4 years 4 months ago #217513
by restore49
That repair may be 40 years old - long before that entire area was saturated and contaminated with oil. To try brazing now may be very very difficult. Solvent a little die grinding epoxy or large iron and solder once the small weep is found. Bob
4 years 4 months ago #217520
by AJ.
Yes it can be repaired, clean off all that slobber, a competent welder will braze that up neatly, if someone that worked at my place let a job out looking like that it would be their last one, make sure the engine is sitting comfortable and bolted up properly when you put it back.
AJ
Thank you received: 16
4 years 4 months ago #217536
by Mangoman
Thank you everyone for the input. I am inclined to clean it up and give it my best to do a braze repair on it. I will remove the pony and do a complete disassemble on it. I want to check everything out. Will do repairs as necessary but hoping to reuse as much as possible. Will check crank, rods, bushings, bearings, cylinders and reseal. Will keep you all posted.
Nathan
Time to create page: 0.137 seconds
