Cat D6-9U mag timing procedure. HELP!
Thank you received: 409
Thank you received: 341
4 years 4 months ago #216839
by edb
Hi Neil,
from a D6, 4R-5R, Parts Book, as the D6 U P/Book, does not have all the gear tooth counts noted--it is 18 teeth on both the crank drive gear and the mag. drive gear, the idler gear is 44 teeth.
4 years 4 months ago #217049
by docrw
It’s working now!
EBC your pictures did the trick.... Not only did I get the pony running but it was running better than ever, enough to start the 318 for the first time in nearly 4 years!!!! I have many things to do before using it, one problem is the oil for the turning levers, I loose it before long (I believe it’s 30W) also what kind of hydraulic oil does this use?
Thanks again!
Thank you received: 9
4 years 4 months ago #217056
by ccjersey
The oil disappearing from the steering booster is usually leaking out the drive shaft seal and adding to the transmission/bevel gear oil.
It’s not a complicated fix, but you do have to take the seat tank off and remove the booster to flip it over and unbolt the sump/pump to replace the seal. Some have oil leaking out the front where the steering clutch levers linkage pushes the plungers. That is a bit more complicated but can be done as well if that’s part of your problem.
4 years 4 months ago #217143
by docrw
I sent you a pm.
I need to do this procedure and need help. Oil runs out as fast as I pour it
Thank you received: 44
4 years 4 months ago #217150
by GrantJ
I just re-read this thread and almost gagged when I saw $400 for a mag rebuild. I recently had my Cat 22 mag (WICO) rebuilt by OLD CROAK MAGNETOS, and it was less than $150. They said it was in good shape and didnt need too many parts, but I had broken the cap, so I decided it was time for a rebuild. That included a new cap and changing the front bearing and seal. They were also very helpful with numerous emails back and forth explaining things. My 22 now starts easy and runs better. I will be sending them a pony motor mag from one of my other Cats for rebuild. Lots of people have mag problems, or create them like I did by breaking the cap and I think a reasonable cost overhaul is well worth it. Grant.
Time to create page: 0.155 seconds
