D6Useries throttle
D6Useries throttle
4 years 4 months ago #216385
by JackD6-5R
Having problem with throttle not holding position when about half throttle. Stays for a little then drops to low idle, throttle lever falls to idle position , is there anything other than the ratchet assembly on the side of the governor assembly that holds throttle setting?
D4D D65R D73T 933C HT4 955H Gardner Denver comp.318 Cat.
Thank you received: 9
4 years 4 months ago #216397
by ccjersey
No
That circular “rack” or stationary ring with internal teeth 5f2880, may have a worn section. Seems like it can be removed and rotated a quarter turn to get better teeth in the important area.
The whole ring assembly with dowel pins, screws etc 7F1644 is listed as well
The pawls that engage the ring are 5F2220, springs are 7F2359.
4 years 4 months ago #216415
by JackD6-5R
Thanks for the response , I wanted another opinion before I tore it apart , I never had this problem before.
4 years 4 months ago #216423
Those governor ratchet parts are rare and expensive. The ring can be rotated but you give up the dowel location. I have got by changing pivot pins to bolts of the right clear shank, cut down with self locking nuts. I use the bolt to squeeze the yoke joints just enough to get the friction desired.
D6Useries throttle
Time to create page: 0.134 seconds
