Removing pony motor from flywheel housing
4 years 5 months ago #216164
by Dan
Hi All,
I haven't pulled the pony motor off my D2 4U crawler before, but now it is necessary. I have disconnected everything required including all the sneaky cap bolts and nuts. Now I find the engine is securely stuck to the gasket stuck to the housing. Using a sling in the manner shown in the service manual, my question is, how much force can be applied pulling upwards before damage occurs somewhere?
Thanks for any advice,
Always appreciated.
Thank you received: 46
4 years 5 months ago #216167
by dpendzic
are you sure you got all the bolts out? I forgot what the count is--someone should come along with the number
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
Thank you received: 620
4 years 5 months ago #216169
by Rome K/G
Two nuts on the left side three nuts on the right and three capscrews between the diesel block and the starting engine from the left side.
4 years 5 months ago #216170
by Dan
Hi dpendzic.
I'm pretty sure I removed all the nuts and cap bolts. 3 under the right cylinder head, 3 under the left cylinder head in an L shape configuration, and 1 longer cap bolt and 1 shorter cap bolt between the pony and diesel engines. by my count it's 6 nuts and 2 cap bolts, 8 in all.
Thank you received: 39
4 years 5 months ago #216171
by bernie
I recall eight (
. Two in front; two on right side Beneath Spark plug ; one on left side Beneath spark plug; one tucked in corner behind the pinion oil cup; two on rear on corners each side of flywheel. Two dowels.
Whe I removed mine the first time a few years ago it was a little tight. Pull it backwards there’s more movement and it’ll free it up off the main to starting engine coolant chamber seal. Make sure the exhaust isn’t getting jammed under something. Drain oil and coolant and remove the compression lever. Don’t pry corners too hard.
Have Fun!
Bernie
4 years 5 months ago #216172
by Rome K/G
Yes your right, just keep lightly nudging it with a pry bar, it should come loose. This is the base gasket. Small holes are for the dowels.
4 years 5 months ago #216179
by Dan
Thanks for adding the picture. yup i'll keep nudging it till I hear a magic solution.
4 years 5 months ago #216181
by Dan
Success! gave it some more serious umph and it broke free. Thank you gentlemen for your advice. I thought it better to ask than risk more trouble. Cheers.
Thank you received: 409
Thank you received: 31
4 years 5 months ago #216195
by oldbeek
The best utility tool ever made is a standard hive tool. Mann lake supply in Minnesota sells a good strong one.. Spring steel, can sharpen edges to razor sharp. Best pry bar ever for this type problem. Great gasket scraper also. I cant be without 2 of them.
