D2 3J donkey engine
D2 3J donkey engine
Thank you received: 10
4 years 5 months ago #215980
by caterpillarsam
Hi all
I am rebuilding the donkey engine on my 3J but unfortunately i do not have a parts manual that covers my serial number, the closet i have is a 3J1 to 3J5000 parts book.
Cutting to the chase, I need the part numbers for:
the two crank shaft bearings
the two crankshaft seals
a pair of head gaskets
Thank you very much in advance
D2 3J
WW2 Huber three wheel road roller (D3400 engine)
1937 Twenty Two
Cat SCOTE engine
Allen Oxford drawbar grader
1944 D7 4T1154
D8 8R
1956 David Brown 25C
1954 DW-15 scraper 45C653
4 years 5 months ago #215983
by Sidewinder
I ordered a pair of head gaskets for my D2 5J5830 donkey engine from Finning UK for when I finally get round to stripping my donkey engine. The modern part number is 488-8155 (old number is 6F4201). Genuine Cat and were about £39 each, which I didn’t think was too bad.
The crankshaft bearings are according to my parts book: 7B3050 (flywheel side) and 7B3057 (pinion side).
Seal is 4B0818. I believe all of the above are available from Finning UK.
James
Thank you received: 187
4 years 5 months ago #215985
by Mike Meyer
Most the parts are available for those motors though good crankshafts are harder to find, plus the crankshaft bearings in larger sizes, though some members here have had new bearings made.
New pistons and rings are available here in Oz in any size.
Those gaskets used to be cheap from Cat not that long ago, seems everything has doubled or tripled in price the past 10 years. It is perfectly fine to re-use those head gaskets if they are not damaged, good luck with the rebuild, there are a thousand old threads and discussions here about rebuilding them, big challenge is getting all the cooling passages cleaned properly.
Mike
4 years 5 months ago #215990
James
That's a 7B3059 bearing (my eyes aren't any good either)
Some of those part numbers have most likely changed from original.
Thank you received: 153
4 years 5 months ago #215995
by rax200
Hi All,
Here is a basic list for gaskets for the pilot motors and there updated part numbers, this includes the seals too. I have not included the baerings or rings.
Ps can somone pleade turn the photo.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Thank you received: 620
4 years 5 months ago #216025
by caterpillarsam
Also does anyone know the new part number for the L-935 lock tab ?
D2 3J
1937 Twenty Two
Cat SCOTE engine
1944 D7 4T1154
D8 8R
Thank you received: 104
4 years 5 months ago #216026
by Deebo
9M-1367, I believe.
D2 3J donkey engine
Time to create page: 0.184 seconds
