Question about a d2 steering clutch bearing
4 years 5 months ago #215966
by RayMiller4288
On a d2 steering clutch there a throw out bearing that I'm replacing. In the shop book it says it should say thrust on the bearing to tell which way it goes. Will a regular bearing work?
Thank you received: 620
4 years 5 months ago #215969
by STEPHEN
Not for long, and considering the effort to change them It's not worth the risk. It should be interchangeable with a 72xx series bearing. Ask your bearing supplier for an angular contact bearing.
Thank you received: 409
4 years 5 months ago #215972
You can get that bearing new Ray. I did two a couple of years ago:
2B9338 or NTN7211X1 $76
4 years 5 months ago #215979
by RayMiller4288
I bought two bearing from general gear and they were open with no dust seals and the dirt dust and moisture rewnd the old bearings
Thank you received: 187
4 years 5 months ago #215986
by Mike Meyer
I've replaced those bearings in early D2 and D4 and they are not sealed, they need to be that way so the oil you squirt in the oil cups up top can enter them through the drop tubes, later model tractors went for grease lines and zerks to lube those thrust bearings.
4 years 5 months ago #215987
My installation was a grease version. I packed the bearings thoroughly with grease and then pumped them up while it was open to make sure it was thoroughly set up.
4 years 5 months ago #215989
by RayMiller4288
Ok I didn't think of that . That's why the old bearing froze up because they were closed up and couldn't get the oil in there and they were regular bearing not thrust bearing. Thank u for ur help I want to get it ready for a plow day.
4 years 5 months ago #216003
by STEPHEN
I remember them having a sheet metal shield with an assembly arrangement in the cage that allows the oil in and blocks the dust. While you have it apart, throughly clean & paint inside the housing to keep the contamination away from all the moving parts.
