Sealant on gaskets?
Sealant on gaskets?
Thank you received: 23
4 years 5 months ago #215789
by Cat Yellow1
I'm about to put the manifold, flange, and cover over the timing gears. I'm not planning to use a sealant but got to wondering if it would be a good idea. What do you all think? Gaskets are not from Cat.
Thank you received: 39
4 years 5 months ago #215799
by bernie
Several good posts on this you can find under search option. More than I could help with here.
Advance Search “permatex”
Thank you received: 620
Thank you received: 142
4 years 5 months ago #215807
by bursitis
depends on the gasket and application. some are better left without,especially if you need to remove in the future.
Thank you received: 48
4 years 5 months ago #215808
by mog5858
if you feel the need only do one side if you ever have to take it off that way you have a better chance of not wrecking the gasket.
Thank you received: 19
4 years 5 months ago #215814
by u-joint
It's real simple. If you have to use silicone with a gasket to get it to seal something is wrong and it won't seal anyway! Dry gaskets used will let 2 parts bond as one. Put silicone in the mix and your 2 parts will not bond as one. The silicone will let the 2 parts move separate from each other. I absolutely would not use it on a heavy cast block to a heavy cast timing cover? Silicone works real well on your bathtub!
Sealant on gaskets?
Time to create page: 0.159 seconds
