Want to add a PTO
Want to add a PTO
4 years 5 months ago #215643
by Christopher
I have a 1944 D4-2T. How would I go about adding a PTO to my unit?
http://www.acmoc.org/bb/attachment.php?attachmentid=75720&d=1526622651
Thank you received: 10
4 years 5 months ago #215653
by crookedwrench
I have a unit that is for a D2. I do not know if it is the same as for a “4”. It has a belt pulley on it. Recently added a Hyster D2N unit to the 4U series D2. It is certainly available for sale. Don 270 993 1191
Thank you received: 44
4 years 5 months ago #215681
by GrantJ
The photo appears like you have the upper mounting brackets for a winch. Dont toss those extra brackets, since they will help if you ever mount rippers. The transmission case is not strong enough to mount rippers directly to it. If you dont plan on rippers then maybe someone will buy them rather than having to make their own. Just my 2 cents worth. Grant.
Thank you received: 409
4 years 5 months ago #215684
Wally might have a D4 pto for you. I'll message him and see if he has. It might need some refurb but there's not much to them other than bearings, seals, and gears. They're generally never not in good operational condition.
Thank you received: 187
4 years 5 months ago #215699
by Mike Meyer
A photo of one here in Oz on my early RD4, plus a unit I bought off a D4 6U years ago that came with a belt pulley.
4 years 5 months ago #215700
by Christopher
I'm hoping I will be able to use a lot of the parts from my '50 d4-7u such as the hitch. Also, someone cut the frame and removed the blade. So it can't push anything and it can't pull anything so essentially its a five ton golf cart. I'm hoping to find a way to mount the blade from the 7u to the 2t.
4 years 5 months ago #215701
by STEPHEN
Are you looking for a belt pto, a shaft pto, or the shaft/ belt convertible style
Want to add a PTO
