D7 3T radiator neck
D7 3T radiator neck
4 years 5 months ago #215477
by Albertagary
Hello Guy's;
I have a D7 3T that has a damaged radiator neck.Rad cap doesn't fit good.Do they make replacement slip over necks to repair?I know they make some for Old JD Tractors.Thanks
Thank you received: 409
4 years 5 months ago #215504
I know the one for the D2 is listed as a separate part number - check your parts catalog to see if it is for your D7 serial # then try Cat, machinerytrader, and Florin. Mine is dented and comes out but I'm in no hurry to deal with it as the cap can be fitted / removed and it doesn't otherwise give problems. I haven't run it under rated power though, or for any appreciable length of time so it might become an issue for me.
4 years 5 months ago #215509
by JackD6-5R
I used a Fernco coupler that has a reducer to get to a smaller size and put cap on it. I got rubber fernco coupler at tractor supply store. It also got water level a little higher in rad, to keep water up in head if working downhill. Not sure about spelling of coupler brand.
D4D D65R D73T 933C HT4 955H Gardner Denver comp.318 Cat.
Thank you received: 6
4 years 5 months ago #215528
by Andrew
Does your machine have a brass radiator top tank or is it the later tractor with cast tanks??
4 years 5 months ago #215576
by Albertagary
My 3T has a brass neck. thanks for all the help.
D7 3T radiator neck
Time to create page: 0.168 seconds
