- Thank you received: 0
s.n. pl 5190
How do i adjust clutch brake or is there not any adjustment to it.
it looks like when you adjust clutch every thing that makes brake work also goes with it.
farther away from brake lining as lining is bolted to transmission shaft.
I have replaced lining on clutch which was not wore much.
Lining on brake looks good but anybody have a thickness measurement.
It is a hand clutch operated machine
Growlyone
If the twenty is like the twenty-two, there are three sets of holes on the clutch brake housing to allow for adjustment of the brake. Just remove the capscrew, index to the next hole, which brings the brake lining forward, then replace the capscrew. See example from my twenty-two. Rays.n. pl 5190
Growlyone
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
