Can i run cheap tractor supply hydraulic oil in Cat 955L
4 years 5 months ago #215189
by cg3p0
I had picked up a bunch of it from tractor supply not really knowing what i was doing, now im questioning if i should use it or not.
It is this stuff
www.tractorsupply.com/tsc/product/travel...rans-hydraulic-fluid
Book calls for a 10W for the hydraulic system which is what i would be using it for
This stuff is 10W-30
Is it going to hurt to run that or should i take it back for something else. Hydraulic system takes a lot of oil, trying to $ave $ but dont want to break it with the wrong stuff.
Thank you received: 46
4 years 5 months ago #215194
by dpendzic
I use that stuff in my wheeled tractors where the trans and hydraulic system use the same oil--but in my dozers i use hydraulic oil in the hydraulic system--R&O aw 46 which i get in Sams club--I think TSC has a standard hydraulic oil also
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
Thank you received: 9
4 years 5 months ago #215204
by ccjersey
It should be fine. Additive package is more extensive in that than a straight hydraulic oil so I think it will be fine where you don’t have clutches and brakes.
I am using some in my 922b wheel loader. I had the main hydraulic hose between filter and valve in the tank burst the other day. By the time I realized it, there wasn’t much left and it needed changing anyway!
I didn’t have a book at the time and I just grabbed 15 gallons when I had the new hose made thinking it probably held about 10. Well that 15 gallons disappeared and no sign of the oil in the fill neck so I grabbed another 5......that disappeared too. Operators manual came in the mail and it says capacity is 25!
Also has a procedure to get the maximum amount of the oil out of the system which I couldn’t do because the hose had burst, but I’ll know next time.
4 years 5 months ago #215206
by ccjersey
4 years 5 months ago #215208
Original spec for hydraulic system is SAE10W. Closer to a ISO 32. ISO 46 will be slow to pump at cold temperatures.
4 years 5 months ago #215300
by drujinin
"mo" is Missouri?
I wouldn't think a slightly thicker oil in an older system would hurt?
Time to create page: 0.153 seconds
