I have a 14A D8 (8430) and it seems to be pumping oil from the steering clutch control compartment into the the right side steering clutch compartment. Is this even a possible? The clutch control is always low and the steer clutch compartment is always over full sometimes as much as 4 inches. I assume there's seals between the two? Thanks for any advise.
