- Thank you received: 0
The new aftermarket ones I've seen have a slightly different face on the ceramic washer, the ID and OD of the sealing face are different giving less sealing surface.This brings me to a question I have. As I said, all of the replacement seals I’ve ever seen before this last year have been a unit. The seal carbon ring and rubber bellows have been glued into the brass cup. Last year I ordered a few from an aftermarket supplier and the “guts” is loose in the brass cup with just an o-ring on the base to seal it. I’m guessing this is the way they are supposed to be? Seems a bit shaky to me compared to having it cemented in but what say you? I’ve got a couple on hand.
I am in the process of rebuilding the water pump on my D2 5U. This is how I found the bellows seal cage when I took it apart. Does this look correct, or do the "lobes" need to be seated on the larger slots?
Found a Pic off the new after Market seal I hadThe new aftermarket ones I've seen have a slightly different face on the ceramic washer, the ID and OD of the sealing face are different giving less sealing surface.
Would love to see a picture of the new aftermarket ones you have to compare against the one in picture that d4angelo posted.
Regards
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
