choking the pony, or are you?
Thank you received: 409
4 years 6 months ago #214536
I'll check my plate the next time I have it open and see if I can estimate how open it is on the current throttle idle screw setting. I'm sure it's just a whisker open because I recall that when I fitted the carb, I initially set the screw so it was just touching with the plate fully closed. Once I got it started, I opened it up a hair. Probably also depends a little on how big those grooves are. Eyeball says there's a bit of variation between the ones I've seen. At the end of the day though, if we get a good idle, that's the main thing : )
I couldn't be happier with my idle because I can start it at low idle even in cold weather, and I like that for its (hopefully) journal saving properties
4 years 5 months ago #214573
by Chuck C
My D25U has the factory shut off valve on the left side of the pony. I have had to take the stem out of the valve body because crud has plugged up the valve. I take the stem out with the main shut off open and flush the crud out. I put the stem back in and the pony usually starts right up.
Chuck C
4 years 5 months ago #214588
by Riverina d4
Chuck C
That sounds like good advice, mine is a 5U with the same valve set up you mentioned. Will do that check tomorrow. I'm confident it's starving for fuel.
Thank you received: 31
4 years 5 months ago #214704
by oldbeek
This is a dangerous procedure I learned from an old timer. Do it only outside and away from flame or ignition. To test a carb off the engine. Set it up with a clear open area below it. Fill the fuel bowl. With you on the up breeze side, put an air nozzle directing flow through the throttle plate. If carb is correct, you will see the atomized fuel flow out of the bottom. Atomized fuel is extremely volatile. Be careful. One short shot of air will prove carb OK and ready to reinstall or not. Don't over do it.
4 years 5 months ago #214765
by old-iron-habit
If you have slow or stopping fuel flow loosen the gas cap to insure you don't have a clogged vent in the cap.
1937 Cat #11 tandem auto patrol,diesel, w/plow and wing, 6K506SP, 1937 RD 4 Ag Crawler RD5356, 1939 Cat 22 2F5429, 1952 Model 212 Grader 9T03427, 1953 2U D8 Dozer 2U20751, 1961 922A Rubber Tired Loader, 59A812, LeTouneau LS Cable Scraper, Cat/Lincoln 600 AMP Dual Welder, DW-21 Cat Scraper, DW-10 dump wagon/water wagon
4 years 5 months ago #214798
by Riverina d4
Yes, my breather cap is blocked so I remove cap to start pony. Removed and inspected fuel taps which were all clear. So will have to remove and inspect carb again.
4 years 5 months ago #214837
by Chuck C
Did you stick a piece of wire into the left side tap after you had the stem out? I had to do that once.
Chuck C
4 years 5 months ago #214848
by Riverina d4
Chuck C
Yes, all clear.
Time to create page: 0.167 seconds
