Fuel guage
Fuel guage
17 years 8 months ago #1831
by railroadjoe220
I have a D257 I need to make a fuel dip stick for the seat tank.Could someone tell me the lengh ,how the gallons are marked on it.Inches from the bottom that the gallons are marked off.
17 years 8 months ago #1960
Hi RR Joe,
I was able to track down the dimensions for both the early and late D2 seat tanks. Which one do you need? the early pre-#13,237 20 gallon tank or the later 26 gallon model. Let me know and I will email the info to you.
Thank you received: 7
17 years 8 months ago #1968
by yellercat
railroad joe has a good question there. Needing the same information for my D6-9U Mag', can you assist?? It is a seat tank of course, but those contours really make it difficult to guess the gallons remaining in there. Its good information to have when you try to keep the tank full after every run and need to schedule the fuel truck to fill the (230 gallon) stand tank.
Any thoughts on what would be best to make the 'dipstick' out of?
tanks-
D6-9U
17 years 8 months ago #1993
Hi yellercat,
Yes, I can get you the dimensions. Was going to do it today but forgot.
Tomorrow should do it.
17 years 8 months ago #2003
by yellercat
No hassle Ole Mag' , whenever you can get around to it. I'll make a note and put it with my other notes. Length and marks from top or bottom (or both) will get me there.
Any idears on what to fab it from?
yellerc@
D6-9U
17 years 8 months ago #2089
OK guys,
Here's the dip stick dimensions. I would suggest stainless steel if you can get it but probably will have to be sheared to get the 5/16 width. Would also recommend a little thicker than the .050 in. Kinda limited cause the hole for the dipstick is only 3/8 in. diameter.
17 years 8 months ago #2092
by Dozerman51
I had a friend of mine who is a metal fabricator make one up for me using my old one as a guide. To mark the gallon amounts on the plunger I used steel stamping numbers and stamped them onto the stainless steel plunger.
17 years 8 months ago #2102
by Nico Ensink
Hi O.M.
While you seem to have details handy, would you have similar info for a D4 7U12815 with tank seat?
Would be nice info to store somewhere handy on the board.
Thanks in advance if you have,
Nico
17 years 8 months ago #2104
OK,
Guess I should add both the seat and side tank models D4's. Give me a day or so.
I have given up on this BB ever developing an archive section. It has been a discussion item for years. Doing good just to keep the lights on
Fuel guage
