Twenty Two clutch component availability
Thank you received: 6
4 years 7 months ago #211662
by puffer@rpi.edu
Thanks guys. Ray, what thickness did you tell them to attach to the clutch plate (per side)?
Neil,
I can't recall for sure, but I think I told them to make it 1/4" after I discussed it with them. Same for the clutch brake. I put in new throw out and pilot bearings.
Ray
Thank you received: 409
3 years 10 months ago #223821
Hi Pete,
by any chance did you happen to capture the measurements from the pilot bearing cone (ID and width)? I could look up corresponding cups that would match that cone, and ask someone to measure the cavity that the cup fits into, and that way I can have all the correct parts on hand when I arrive.
To that end, does anyone have a Twenty-Two crank that they could measure the ID of the pilot bearing cup cavity, and the available depth?
3 years 10 months ago - 3 years 10 months ago #223841
by Peter C
Neil, the pilot bearing (part # 1B-3739) is 0.945 inches front to back. The inner race is the front end of the transmission input shaft. Caterpillar told me that the outer race was unavailable. The outer race is pressed into the flywheel, not the crankshaft.
I got the pilot bearing from Caterpillar.
Pete
Last edit: 3 years 10 months ago by
Peter C.
3 years 10 months ago #223845
Thanks! Interesting - same part # as the roller assy. for the D2 5U. The race for the D2 is 1B3740 - is that what you have for the Twenty-Two?
3 years 10 months ago #223853
by Peter C
The Cat 22 parts book shows that the 1B 3738 bearing assembly consists of the 1B 3739 roller assembly and the 1B 3740 race. I don't know how the parts guy searched for the race but I thought that I gave him the part number from the 22 parts catalogue.
I hope that you can find it.
Pete
3 years 10 months ago #223858
Cool! Thanks Peter, that makes both of them a match with what the D2 uses. I know I put a new race in my 5U and I bought it from Milton Cat so I'll ask them for another set and see what they come up with. If they can't find the race, I'll try Dana, and if I can source a brand new one, I'll get the measurements from it so it can be matched to a generic from SKF etc.
Thank you received: 50
3 years 9 months ago #223948
by hfdzl
Hi Gents, I have some of the 1B3740 bearing races will fit 22/D2 others.
Herb
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
Time to create page: 0.158 seconds
