Gas 50
Gas 50
16 years 2 months ago #18420
by Jbayer
Just bought a fifty last weekend. It is a little locked but it will turn a little. Enough to get the pistons to move about an 1/8 of an inch. Everthing looks to be OK. The gears in the front timing cover are rusty and scalely looking. At first I thought the camshaft was stuck because the crank moves this much but after taking the governor cover off I can see it moving a little. Got diesel soaking in the liners. Just wondering if it would be wise to remove the heads or just keeping working the crank a little at a time. For those of you that read my post about hauling this one, I ended up getting a truck which worked great. We loaded it with a 3020 on one side of the trailor and our RD4 on the other side. Thanks for the advice everyone!
16 years 2 months ago #18425
by 7upuller
Try mixing some ATF with the soaking diesel. Let sit a week or so. Then try it again. Good luck-glen
Thank you received: 279
16 years 2 months ago #18429
by Deas Plant.
Hi, Jbayer.
If the above doesn't work, try putting some Pepsi-Cola in the bores and ONLY leave it for 24 hours AT MOST. Then flush it out with diesel fuel or similar and compressed air. Be careful when using the air that you have protective clothing and GOOD eye protection - like sealed goggles. A good long blowing nozzle for the air is a good idea too.
If that doesn't get it freed up, look at removing the heads and doing some more drastic surgery.
Hope this helps.
Thank you received: 20
16 years 2 months ago #18431
by 8C 361
Why not pull the valve covers and see if you have stuck valves. If it moves a little the pistons may not be seized. You can remove the rocker assys and see if it turns over. You can probably free up the valves one at a time.
Tom
Thank you received: 191
16 years 2 months ago #18439
by D4Jim
Kroil it. If you use Kroil to unstick an engine you will never use anything else.
Kroil will loosen things that diesel and other fluids wont even touch. It isn't cheap, somewhere around $40 per gal but well worth it.
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Gas 50
