i pulled the whole housing with the axle out how do i get the sprocket off i see a large threaded part on the outside off the sprocket is it pressed on
thanks for ant info
You will have to take it to a Cat dealer or a place that has the HD puller setup to remove the sprocket from the hub as it,s not a back yard job as the special puller tools are needed.They are necessary to press the sprocket back on too with the correct tonnage.
