Hydraulic track adjusters will not budge
Thank you received: 46
4 years 10 months ago #208144
by dpendzic
Ouch on that blade!! try releasing the adjusters and pull them back a bit and then pump them up--they may tighten the track then.
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
Thank you received: 620
4 years 10 months ago #208161
by jstandle
"that blade is not made for stumps or trees!!!!! Thats for light grading!!!!!!"
In my defense, I've just been piling brush and leveling old rotten stumps. The mistake here was this was an ancient pitch stump that I should have avoided. But yes, it's not made for that as I have learned, lol
Jordan
4 years 9 months ago #208681
by jstandle
It looks like soaking mine with penetrating oil made the difference as I was finally able to get mine to start moving. I hosed both sides down with PB Blaster a couple weeks ago. I was getting ready to switch to a 50/50 mix of ATF/Acetone as that has by far been the best solution I have ever used but before applying that I tried to pump some more grease in and low and behold both sides un-seized and started to move.
Now I just need to get the blade glued back on........ lol
4 years 4 months ago #217096
by jstandle
After I got mine to move and ran the machine awhile I found they weren't holding very long so I had a retired Caterpillar mechanic rebuild them for me. Unfortunately when I filled them back up I thought I had blown one of them not paying attention using our electric grease gun so I took one side back apart to check. I went ahead and filmed some of the disassembly the second time around so maybe that will help others who need to do rebuild theirs;
Thanks,
Jordan
