955k serial number
955k serial number
16 years 2 months ago #18221
by fabman72
Hi guys i need to find out the serial number of my loader there is a aluminum tag on the back rearend housing that looks like it had the number but its not readable is it stamped anywhere on the machine thanks James
16 years 2 months ago #18248
by SJ
Chances are you have an 85J 955K loader made in USA. Check where OM stated but some of the little later tractors have a different SN engine than the tractor so check above the draw bar first and all that I remember had the SN stamped in the housing if the plate was missing and was directly behind where the plate was riveted on so take a lok there if the plate is missing.
16 years 2 months ago #18257
by fabman72
i found some numbers on the motor 61H1445 does anyone know what year it would be im looking for final drive parts
thanks for the info guys
16 years 2 months ago #18260
by SJ
The Cat SNID book shows that the 61H came out in 1966 and the 85J followed in 1968 so yours probably is in between that like a 1967.
16 years 2 months ago #18261
That would be a 1967 model...they only produced a couple thousand 61H's, as opposed to the 12,000 85J's covering 1968 - 78.
16 years 2 months ago #18292
by fabman72
Does anyone know if the final drive parts from a 85j will fit the 61h my left side outer case is in pieces i can see the pionon gear and the bearing
thanks again for the help
16 years 2 months ago #18293
Maybe 85J prior to sr. # 1795......at #1796 changed to coarse pitch final drive gears.
I don't have enough information to advise, sorry.
955k serial number
Time to create page: 0.147 seconds
