- Thank you received: 0
I forgot to ask does anyone now if there are any of these frost plugs under the valve covers?
Only about 28.
Bob
I would not ever start an engine with just diesel instead of oil. Much better to spend some money on another oil change than to take a chance of damaging some bearings.
But what’s done is done so let’s hope you were right and I am being an opinionated old codger!
Just did an in-frame overhaul on an 855 Cummins because several injectors apparently went bad and it scored the cylinder liners and scuffed the pistons. It was a sudden failure with immediate loss of power and a huge amount of blow-by, so the oil didn’t get diluted and the bearings were still fine.
AT BEST, the cost and time to repair would have both probably doubled if it had failed a crankshaft bearing.
At WORST, there would have been very little salvageable below the heads and above the oil pan.
Doesn’t pay to take chances with lubrication and bearing problems.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
