9U 17 in the shop.
9U 17 in the shop.
Thank you received: 77
Thank you received: 183
3 years 7 months ago #226087
by d2gary
I have both oil and temp. The temperature would have to be repaired and both faces would have to be cleaned.
Bruce P
3 years 7 months ago #226089
by Bruce P
Oh cool! I actually found an oil pressure gauge today that I'd forgotten about, but I'd definitely be interested in the temp gauge! Thanks a bunch for looking! I'll send you a pm.
Bruce.
3 years 7 months ago #226107
by Bruce P
Fussed with 17 most of the weekend. Swapped out a valve cover and adjusted the valves. I had found the fuel pressure relief valve and spring were rusted away when I first got it going after it had sat for so long. I decided to remove the transfer pump and check it out. I found some really ugly pump gears. While I was there I also decided to take the injection pump off and change the fuel gallery O ring seals.
Thank you received: 153
3 years 7 months ago #226108
by rax200
Hi Bruce,
While you are this far I would change the seal on the injection pump as well in the last photo.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Thank you received: 409
3 years 7 months ago #226110
Interesting that one of the pumps has a bleeder and the others don't
3 years 7 months ago #226111
by Bruce P
Hi Bruce,
Regards
Hi Daryl. Thanks and yes I did change that seal. I will say that the new one from cat wasn't nearly as robust as the old one.
BP
3 years 7 months ago #226112
by Bruce P
I thought so too, I suppose they left one to bleed the fuel rail.
BP
3 years 7 months ago #226113
Heh, I kept an old Chicago Rawhide seal that I replaced in the 5U as a souvenir, since it was an example of very robust construction
3 years 7 months ago #226180
by Bruce P
I found this tube in the filter tower rusted out, so I replaced it with a piece of copper tube. Found a pretty good oil pressure gauge, and d2gary sent me a nice temp gauge.
BP
9U 17 in the shop.
Time to create page: 0.385 seconds
