I need to know if the grease fittings for the Cat 10 rollers are "standard" button head 3/8" NPTF or "Giant" buttonhead 3/8" NPTF fittings.
Which is correct?
PT3090
Hi, I'm going through this myself right now for my Ten. The button heads are 7/8" button heads with 5/8-18 NF threads. I ordered 3/8 pipe threads and they are wrong. I have not found any yet with the correct threads. Hope this saves you some time. Maybe someone can help with this. <a href="This email address is being protected from spambots. You need JavaScript enabled to view it." target="_blank">This email address is being protected from spambots. You need JavaScript enabled to view it.
