Can anyone tell me the firing order of a cat 22? The serial #2f5868sp. Are there timing marks on the crank pulley or the flywheel behind the inspection plate? It has spark and compression and fuel:confused:there is a wico mag on it and a set screw is missing on the collar would that be enough to throw it out of time?
hello notmuk,here is the pages for the timing of the 22 ,timing mark are on the front pulley on the right looking back.the firing order is 1-3-4-2.
bruce oz
