Pony Starter Drive
Pony Starter Drive
16 years 3 months ago #17278
by carlsharp
Someone Bubba'd this one up pretty good. I can't even remove the belt. The bearing is shot too, the pulley/gear ass'y wallers around about a half an inch. Also the pulley looks nothing like the one in my parts book, so must have been sourced elsewhere.
Do you think this is salvageable?
Does anyone have an extra one?
16 years 3 months ago #17291
by dratt
Looks like someone welded the pulley on in desperation.
My only suggestion would be to torch off the pulley. Install a new bearing, shaft and find the correct size pulley. Should be able to do it all for less that $100.00
Thank you received: 94
16 years 3 months ago #17292
by josh
Carl,
There are two different pulley/ bearing setups for those starters, try to save the pulley if you can, the bearings should be available.
If I remember correctly one kind of bearing is a ball bearing and the other is a cam folllower style bearing, once you get it apart you will be able to tell which you have.
Pony Starter Drive
