D4h
D4h
Thank you received: 142
5 years 10 months ago #192124
by bursitis
was there problems with the D4H series tractors? what are their weaknesses? i see D4H series tractors for sale pretty cheap sometimes. should i stay away for some reason?
5 years 10 months ago #192131
by PEVO
Got my first dozer... 1987 D4H II back in june this year. You hear all kinds of different opinions like...Its a High track...UC is more expensive wears out quicker. The early models have a 3204di
they call it a throw-a-way motor(because it only has 2 rings per piston). Its a in-between size dozer. Too big and heavy for small jobs and too under powered and light for big jobs...what ever that means. It is close to a D5 sizewise
95% of D4Hs came with a PAT blade...thats a finish work blade and not for pasture cleaning and stumping your blade cant handle it...bla bla bla..kinda like "yull shoot your eye out kid"
They are heavy 23-25k also almost 10ft tall. Early models had 95hp then got upgrades to a 3304di with 105hp...larger tranny and other components.
I dont have much prior experience on dozers but i do like that you sit higher up and can see the blade edges good.
Mine is a powershift trans. has steering levers next to trans forward/reverse handle. Still old school no hydrostat. No having to plug it in a computer to figure out problems with it.
They say final drives and tranny can come out in 4-5hrs time.
So far im satisfied with mine but thats just me.
5 years 10 months ago #192140
by bursitis
i rented one in like 89 or 90 i think. i remember thinking it was a workhorse for a D4 and was very comfortable to run. i liked the PAT blade also. i didn't have it long enough to really give it a fair evaluation though.
5 years 10 months ago #192142
The only issue I have heard about is the track frame pivot shaft having busing wear and if not attended to can lead to cracked pivot bearing housing. More common to the D6 high track but same conditions apply.
5 years 10 months ago #192147
by bursitis
is the housing a part of the track frame or the tractor? if cracked is it obvious or do you have to dis assemble to find it? is a cracked housing repairable or does the track frame have to be replaced?
Thanks OM
5 years 10 months ago #192149
I'm more aware of the D6 arrangement. The bushing housing is part of the track frame. There is a procedure for repair but it's a bear to do.
Here's a pitcher of the damage on the D6N. I would be looking at this area closely on the D4H and any sign of track frame miss alignment.
5 years 10 months ago #192157
by bursitis
Thanks Magnet.
i did some research on this problem and discovered that housing is oil filled. so a good inspection should include checking oil level in those compartments.
4 years 1 month ago #221123
by RP
Someone knows how excess oil drain action occurs in converter D4H 3304 1P9136 0R5799
D4h
Time to create page: 0.186 seconds
