- Thank you received: 0
Hello
Did not spend a lot of my time in general workshop but can remember some repairs to final drives and track frame rebuilds.
Re D6C generally oil leak at the diagonal brace bearing would indicate a loose dead axle and over time can only get worse.
If the owner wants a temp repair we would remove the outer hub (bearing ) cover and remove dead axle nut and check position
of key, as generally when fitting a dead axle we would install with the key up and that may indicate that the axle has turned as
would be the location of the dead axle locking pin.
We would then back off the outer bearing adjustment, fit a dead axle adaptor and mushroom to give it a few wacks with a sledge
hammer whilst tightening the inner dead axle nut.
One issue with this operation was to get the outer bearing housing dowels out so as to get enough thread for the dead axle adaptor.
Regards Gary
Dead axle bore repair is in Conservation Bulletin No 16, Dec 31 1951, as above, previously posted here at least twice before.
You blokes are slow to get the message about saving this stuff to your computers for such future reference.
www.acmoc.org/bb/showthread.php?22193-Co...4&highlight=bulletin
Just be aware that the sleeve dimensions in Eddie's scans are for older machines than your D6C which will probably have a heavier axle.
You might want to look at this post www.acmoc.org/bb/showthread.p...ems&highlight=
For your intended usage, unless the shaft has spun, I'd back off the bearing preload, and do something similar to what L364 suggested previously.
Got lucky hearing about the ram lying in someone's shed. Had to have tooling made up along the way and bought an enerpac pump to power it. Some simple calculations on the ram dimensions with and a small laminated chart stuck to the pump to convert the pump pressure reading to tons force for both cylinder extending and retracting. Working with 70's/80's era machines everyday makes this setup almost a necessity, especially in the case of D4's which never had a conversion to sprocket segments.
There was a pretty neat home made setup to push and pull a D7 sprocket using an enerpac cylinder either on here or the HEF not that long ago.
Best way to see if anything has spun is to remove the outer cover and the big nut and plate which hold the outer hub on its taper. If the keyway is still up top then likely it has not spun.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
