- Thank you received: 504
Booster is located under the seat and fuel tank. Fill pipe and spigot to check the level extends to the rear. Uses 30wt engine oil.
Free movement spec for the steering clutch levers is 2.62"
Adjustment is at the steering clutch yokes in the main case. Access is through covers on each side.
Wanted to let you know I found the s/n on the engine. Small stamped number on the side of the block.
53A2453 is what she is!! Guessing 61 or 62!!
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
