- Thank you received: 0
Took the generator in for bearings and brushes as it was noisy, it has been together so long the screws were breaking off on the covers and brush holders so changed to an alternator. Pretty easy and tidy change, used the same pulley, cut the rear portion of the bottom mount down 4", drilled and rethreaded for the rear bolt, made a new spacer for the adjustment bracket and it fit perfectly, pulley lines up exactly. Also eliminated the voltage regulator. $200 bucks, I thought it was worth mentioning.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
