- Thank you received: 6
May B dig a trench away from pond @ the lowest point ouside of pond
n run a few siphons over night n it will soon B MT (or close 2 it)
cya
§wishy
HasBeen
It shouldn,t be no big deal to tap in the fuel tank on your 225 so if your not handy at plumbing it up maybe you have a friend that,s either a plumber or even a good mechanic that can pipe it up for you.It should only take a couple fittings & hose hook up to do it.
If you can put a very short suction on the pump and mount it/lift it with the excavator bucket, you can easily keep the pump very close to the water level so it has to lift very little. You want a pump mostly pushing water, not sucking it if at all possible.
It can be hard to keep a pump like that near the water if you have to haul it there by hand through the muck along the waterline. So mostly folks have quite a long suction hose on them and keep the pump up on high ground which cuts the output, causes cavitation damage etc.
If your going to tee off the line to the 225 then after the tee line going to the backhoe engine put a shutoff in the line so it doesn,t suck fuel out of the fuel system in the backhoe engine. I,m guessing your 225 has either a 3160 V-8 in it or a 3208 V-8 engine.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
