1930's 40's 50's D4 dozer eng questions
16 years 5 months ago #15718
by ewingjh
This is my first day on this site as I have just ended up with a total of 2 complete and 3 partial machines. First the later engines of 4.5 bore vs. the early of 4.25 bore - do they use the same bottom end? The later engines have the decompression lever on the valve cover vs. on the 4 individaul cam follower plates. Also is there any call in this group for the older parts ? Thanks Jim
Thank you received: 191
16 years 5 months ago #15720
by D4Jim
Gosh Jim, for a minute I thougth that was JR Ewing!!
If you have the serial numbers of the D-4's that would nail it down as to what engine they had. (If they were original) The serial number would be something like 7U 1789 on a plate on the side of the engine and on the rear of the tractor.
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Thank you received: 9
16 years 5 months ago #15727
by ccjersey
No, bearings etc are different between the D4400 and D315 engines.
If you can keep them, I expect you can move parts from any of them. The most important thing is how close you are to the one who needs the parts (at least if they're very heavy)!
Time to create page: 0.120 seconds
