poney motor
poney motor
16 years 6 months ago #14977
by slurrydog
Hi all, could anyone tell me if a poney motor off a 5u d2 will fit on to a 5jd2.Will I have to change anything?
The pony motor on my 5j has very little compression and the head has been cracked and welded. I had the meg rebuilt so there was spark but I could never get the motor to fire, so I found a different motor for 300 dollars. The only problem is it came off a 5u so hopefully they are the same. Did it sound like I am going down the right track.
I would love any input ,and thanks.
16 years 6 months ago #14978
by Roland
Hi , You will have to do a mix and match,I think the block is the same but not the top manifold etc, good luck with your project:)
16 years 6 months ago #14981
by ol Grump
Hello slurrydog. .Roland pretty much nailed it with the mix'n'match. Where in OR are you? Eastern part here
16 years 6 months ago #14986
by slurrydog
Thanks for the help guys, so if I understand you right than I just have to swap out the top mnifold but other than that it should work. That is good news with the weekend coming up maybe I can get some good things to happen.
16 years 6 months ago #14987
by slurrydog
Hi.olGrump, I am in Cottage Grove 20 miles south of Eugene. What part of eastern are you in. Thanks again for yours and Rolands help.
16 years 6 months ago #15005
by ol Grump
Hi slurrydog. .I'm in a little town in the Blue Mountains called Granite. Still lots of snow on the ground here still at this altitude but it's starting to melt off slowly.
16 years 6 months ago #15014
by slurrydog
Hi ol Grump, I THINK i know where Granite is, is it by Sumpter?
My dad worked for a road building rock crushing company, and they did alot of work and spent alot of time in and around the LaGrande area. There last big raod job was when they widened and paved the road that goes from Astin to Sumpter, back in 1979 to 1980. I think it went over Timpten pass,anyway that was a neat company because they had a 933 a977 6 or 7 d82u and 2 d846a also 4 or 5 old Northwest rock shovels. The best time of my childhood was watching that old stuff work. Any way good info on the float i will keep that in mind.Thanks.
poney motor
Time to create page: 0.155 seconds
