D6 9u electric starter
7 years 5 months ago #161912
by Tydavis
I have an electric starter that came with my 9u I'm thinking bout putting on so I don't have to mess with the pony motor all the time. I'll post some pictures of it and see if any of you guys can identify it. I can't find any tags or anything on it besides a few numbers.
7 years 5 months ago #161913
That's a really crappy picture of the s/n. Those cell phone cameras are the pits.
1115556 is a starter solenoid for a Delco 50MT starter.
7 years 5 months ago #161919
by Tydavis
Thanks for the reply old magnet. Yea they don't take the best pictures. Does the 12v on the second number mean it's just a 12 volt? I don't get why it has two solenoids on it.
Thank you received: 9
7 years 5 months ago #161921
by ccjersey
The auxiliary solenoid makes the ignition switch last a lot longer. Most of them aren't really up to the amperage that big solenoid requires
7 years 5 months ago #161934
by Tydavis
Thanks for the information. Has anyone put these on the 9u before? Some of the bolts to bolt it to the housing you can't get on them to tighten them really at all.
7 years 5 months ago #161936
by old-iron-habit
For the bolt against the block use the smaller headed bolt style which takes a twelve point socket. Them style bolts have a name but can't remember what they are called. You can easily tighten them with a long extension and a swivel on the socket.
1937 Cat #11 tandem auto patrol,diesel, w/plow and wing, 6K506SP, 1937 RD 4 Ag Crawler RD5356, 1939 Cat 22 2F5429, 1952 Model 212 Grader 9T03427, 1953 2U D8 Dozer 2U20751, 1961 922A Rubber Tired Loader, 59A812, LeTouneau LS Cable Scraper, Cat/Lincoln 600 AMP Dual Welder, DW-21 Cat Scraper, DW-10 dump wagon/water wagon
7 years 5 months ago #161947
by d9gdon
12 point flange head cap screw is what I think you're talking about.
7 years 5 months ago #161962
by old-iron-habit
I believe you are right. The fastener store will know if you describe it.
7 years 5 months ago #161967
I can't tell if you have the right drive end housing (looks right).
You need to grind a slight relief in the lever housing to clear bolt and 5/8" wrench. Assemble with bolt in place on the starter.
7 years 5 months ago #161991
by cojhl2
Also on my IH544 more often than not, when you hit the starter switch it grinds on the flywheel. What Ive been thinking of doing is install that second solenoid to
merely close the circuit to the starter and leave the original solenoid to engage.
Do you think that would work and/or help the grinding situation?
9U(2), 5J, IHC544, Ford860
