Just got a Traxcavator 933 and I'm serial number challenged
7 years 6 months ago #161096 by bobhead
I just got this 933 (at least that's what it claims to be) and I need to find the serial number. I searched the forums but I can't match up the suggested serial number locations to anything I can find. Previous owner says he never found it either.
The closest I've found is this location on the side of the engine block. It appears to have had a plate there at one time but no more. There does seem to be a number stamped there but it doesn't match the format that I think I'm looking for (looks like 5?10)
I've also looked "behind the seat" (in the battery compartment) but haven't found anything there.
I'm sure I'm just looking in the wrong places. Can anyone help me out with rookie (specific enough for dummies) instructions and maybe pictures for where I should look?
Thanks in advance,
Bob
7 years 6 months ago #161102 by Old Magnet
Looks to be a 933 42Axxxx series unit with D320 engine. S/n locations are LH side of engine (tag gone) and LH rear of the transmission case.
7 years 6 months ago #161106 by bobhead
Old Magnet,
Thanks for the reply. The previous owner thought it was "mid 50's" vintage. It does have the 4F,2R gear shift (no separate F/R lever) so wouldn't that that make it earlier than a 'G'? I know nothing about these but I'm learning fast. I'll see if I can find that transmission number tonight.
Thanks again for the help.
Bob
7 years 6 months ago #161110 by Old Magnet
You are correct. If it doesn't have the F/R lever it is pre 1961 and pre 42A2106 which would make it a 933F model with non turbo D311H engine.
7 years 6 months ago #161115 by catsilver
The serial number on these was in three places, on the engine as described, the transmission above the drawbar mount on the LH side and on the loader frame, RH side below the tilt crank main pivot pin.
7 years 6 months ago #161118 by old-iron-habit
If the back of transmission plate is gone but you can see the rivet holes, carefully shine up the area, the serial number should be stamped into the transmission under the tag also.
1937 Cat #11 tandem auto patrol,diesel, w/plow and wing, 6K506SP, 1937 RD 4 Ag Crawler RD5356, 1939 Cat 22 2F5429, 1952 Model 212 Grader 9T03427, 1953 2U D8 Dozer 2U20751, 1961 922A Rubber Tired Loader, 59A812, LeTouneau LS Cable Scraper, Cat/Lincoln 600 AMP Dual Welder, DW-21 Cat Scraper, DW-10 dump wagon/water wagon
7 years 6 months ago #161119 by restore49
They look like cousins - my parts book says I have a 933A #11a1219. Will look for # on loader arm in morning and if I find will post picture location. If we leave them alone in the woods will they produce little clones? Bob
7 years 6 months ago #161120 by Old Magnet
Those three places are where to look but the parts book states only the engine and transmission case and then contradicts itself stating only one s/n tag and two drive screws.
7 years 6 months ago #161132 by bobhead
Thanks everyone. I'm still looking. Is this where I would find the transmission case number?
I found what looks like two rivets but no plate and haven't found anything stamped there.
If that's the right spot, I'll do some more cleaning/polishing and I'll also check the RH loader arm tomorrow.
Bob
7 years 6 months ago #161147 by Old Magnet
Yet another source... the Operation & Maintenance Instruction book says look here (top of the drawbar mount) for s/n. Can almost see the tag where your battery cable ground lands.
Time to create page: 0.184 seconds
