Info needed on Cat D4
16 years 8 months ago #13124 by STEPHEN
I found a D4 for scrap value, which might be all its worth. 7U 32,013 with 4A blade & 44 hyd sys. No winch, It would need rails,sprockets, P&B, engine unsticking at minimum. Please what is the best esimate on weight and year model? Thanks,:confused:
16 years 8 months ago #13126 by Old Magnet
Replied by Old Magnet on topic Info needed on Cat D4
May be some good parts there.....1955 model....will have the later hp balancer engine, and provision for direct electric start.
Bare tractor shipping wt.....10,670 lbs
#44....400 lbs
4A blade set up...2,850 lbs
16 years 8 months ago #13166 by STEPHEN
Replied by STEPHEN on topic Info needed on Cat D4
Thanks OM, what is the HP balancer engine?
16 years 8 months ago #13167 by Old Magnet
The later D4's sr # 7U26583 -up were slightly increased draw bar horse power from 43 to 48. This was done by raising the full load rpm and a balancer was added to cope with vibration closer to critical speed. Easy to spot if you look at the front of the oil pan you can see the rounded bulge to the left of the crankshaft where the balancer lives.
Time to create page: 0.151 seconds
