D2-5J Head
D2-5J Head
16 years 8 months ago #12760
by drujinin
I'm pulling the head off from my D2-5J to change a leaky head gasket and lap a valve or two.
My Service Manual doesn't address Head removal. I got the hood and the valve cover off and realized that the water pump is attached plus the gasket between the pony and the head. How does that come apart? Would anyone mind taking the time to type or scan the removal procedure? You can PM me if you want to scan it large enough for me to read and I'll send you my home address. I just don't want to unbolt alot of extra stuff if necessary.
thanks,
Thank you received: 341
16 years 8 months ago #12767
by edb
Hi drujinin,
here are scans from my 3 3/4" bore Serv ref Man. form no 30525 issue date 10-53 on the above.
Hope this helps.
16 years 8 months ago #12788
by drujinin
I'm glad I waited before disassembly as I would have taken off the exhausts of both engines and the whole water pump assembly after I had removed the radiator to get the water pump off.
D2-5J Head
Time to create page: 0.125 seconds
