Cat Ten Head Studs
Cat Ten Head Studs
16 years 8 months ago #12616
by d4e
Im finally getting time to start working on the Cat Ten. I want to replace the head studs before installing the head.Are they still availble from Cat?.If so I would appeciate the part number,I dont have a parts book yet.I tried one local supplier and the studs were to short .Thanks John.
16 years 8 months ago #12630
by TomP-TX
The studs are still available but cost around $10 a piece. I had to remove some fine thread studs a couple of days ago and when I double nutted them to try and get them out they would just slip on the fine threads. I have a buddy at work that has a stud remover kit that is design for each specific thread, they work just like two nuts but they are bigger and the one piece has a o-ring on it. They worked really well I was suprised how easy it removed them.
12- 0T203 STUD
3- 0T958 STUD
6- 1A3462 STUD
21- 1B4204 NUT
16 years 8 months ago #12664
by Catmatt
There are three different stud lengths for the cat ten head. 3 part no t-958, 12 t-203, and 6 1a3462. They are different lengths for just holding the head, hold the head and the sparkplug wire holed, and holding the head and the heat shield. There was a way to convert the old numbers to the new cat part numbers. I forget how though.
Thank you received: 37
16 years 8 months ago #12665
by naylorbros
I do not know if they change up again but you would ask for 0T0203 for the T203 and 0T0958 for the T958
Ken
16 years 8 months ago #12692
by drujinin
I am curious about the length and diameter of these. Can any of you tell me the lengths and diameter?
Thanks,
Cat Ten Head Studs
