Oil Leak on 17 A
Oil Leak on 17 A
16 years 8 months ago #12581
Hi Ali,
Afraid your SOL:D The bolts/studs are nicely located low and behind the flywheel. Might be able to reach one through the timing pointer cover....maybe.
16 years 8 months ago #12622
by ali sleiman
Hi Old Magnet,
Too bad , it will have to wait till the next clutch change
Does anyone have a source for track covers for 17A
Thank you
16 years 8 months ago #12708
by ali sleiman
We had agood day today, in addition to few successes, I found the source of leak . The oil is leaking from around the compression lever. On this machine it sit high on the right side of the big engine. The oil run down the area of the block behind the air filter. also found another leak if from the oil pressure gauge line.
These 2 problem are easy fixes:cool:
16 years 8 months ago #12711
That's a hell of a lot easier than dealing with the flange gasket:D
Thought you had already looked for the obvious sources as mentioned early on in the posts.
The decompression shaft seal is a 7B280
16 years 8 months ago #12766
by ali sleiman
Hey Old Magnet,
I checked the part number for the seal from my source , it is available and my cost is $1.00 . I think I will get few seal just in case the cussing got out hand
Oil Leak on 17 A
Time to create page: 0.148 seconds
